How fast can you type? 24 hour leaderboard now underway!
69. Not bad - but it had no capitals, characters or numbers so was fairly easy. However, I made a couple of mistakes, which I corrected before pushing the space bar - again probably affects your score.
Managed 86, 100% which will do for now, though I think you do better if you just do a space as soon as you fluff up a word and get on with the next one, and I just can't seem to avoid hesitating to correct the mistake (I reckon I could probably type an extra 3 or 4 words in the time it takes me to backspace and correct the incorrect word)
First attempt:
Words per minute (WPM) 95
Keystrokes 502 (474 | 28)
Correct words 88
Wrong words 5
Will give it another go later and thrash it :P
Probably would've done better if it had made sense.
normal sentences are much harder to type than random easy words; punctuation gives you a big hit to begin with. I know in the past I've hit 150wpm on easy random words and I get around 100wpm otherwise, this I just hit 110wpm on, with a bit of practice I can get back to 150... but WoW RSI flaring up isn't worth it :p
Also just took it again; 120wpm this time and it's the SAME words?! that's even easier then you could muscle memory your way to insane WPM :/
