- 8 Sep 2003
- Was 150 yds from OCUK - now 0.5 mile; they moved
Hi guys.
With stock due next week, the new Zowie mice in all white options are now available to purchase. These offer a unique look with the power and handling of a pro gaming mouse!
We also have the new FK mouse in stunning Black/Yellow
Zowie FK Pro 2300 DPI Optical Gaming Mouse - Black/Yellow @ £54.95 inc VAT
The FK is similar to the AM in terms of specifications and features, and they are both ambidextrous mice developed for gamers who prefer a claw-grip play style, but that is where the similarities end.
The design of the FK has changed slightly compared to the AM, amongst other minor adjustments, the height is lower. The adjustments to the overall design have been made to make the FK lighter and faster. We hope that the design makes it more comfortable to use, not only for gamers who prefer the claw-grip, but also for gamers with smaller hands who prefer to palm-grip their mouse.
Furthermore the FK features a new coating, which feels smooth and fine like regular rubber paint, but has increased resistance towards wear and tear. The coating helps increase grip for gamers with tendency to sweaty palms and it is easy to clean!
- PI (Dots Per Inch): 450 / 1150 / 2300
- Connector: USB
- Buttons: 5
- Length of cable: 2m / 6,6 ft
Only £54.95 inc VAT.
ORDER NOW
Zowie EC2 eVo 2300 DPI Pro-Gaming Mouse - White @ £54.95 inc VAT
1.5 mm lift-off distance - one of the lowest on the market to date
One of the primary features of the ZOWIE EC-series is the lift-off distance. ZOWIE EC-series has made it possible to create one of the lowest lift-off distance currently available in any optical mouse on the market - 1.5 mm.
1,000Hz USB Report Rate - plug and play with 1.000Hz
Most optical mice are 125Hz which can be artificially raised to 500 – 1,000Hz through driver installations. The ZOWIE EC mice were the first optical mice to introduce 1,000 Hz from standard, without any installation of drivers.
Improved mouse wheel
The mouse use an optical encoder instead of the cheaper traditional mechanical system and added a new optimized rolling system developed by ZOWIE, which ensures that the mouse wheel is the most durable and precise mouse wheel on the market today.
DPI-adjustment
Adjusting DPI on the fly is not really an innovative feature, but ZOWIE decided to put it on the mouse anyway, as it's important for a gamer to be able to optimize the settings to create the perfect feeling when playing.
DID YOU KNOW?
That you can change the Hz of the EC-mice without any software?
- 100% stable optical mouse developed by HeatoN
- Ergonomic designed right-hand gaming mouse
- 1.5mm lift-off distance
- Improved mouse wheel system
- Easily change to 1000, 500 or 125 Hz
- Plug and play! No drivers or software
- DPI adjustment: 450/1150/2300
- Operating system: Win2000/XP/Vista/7, Mac OS X V10.2 after
- Frames Per Second: 6,400
- USB report rate: 1000/500/125 Hz
- Dimensions: 120 x 40 x 58-65 mm
ORDER NOW
Zowie EC1 eVo 2300 DPI Pro-Gaming Mouse - White @ £54.95 inc VAT
DPI-adjustment
DID YOU KNOW?
- Dimensions: 128 x 43 x 62mm
ORDER NOW
Zowie AM-FG 2300 DPI Optical Pro Gaming Mouse - White @ £54.95 inc VAT
The AM is a series of ambidextrous mice that is unmatched by other mice in flexibility, stability and performance. The AM features two buttons on both sides which allows the user to switch between left- and right-handed usage. Only one side may be active at a time, thus eliminating annoying situations where you accidently hit the opposing side-buttons, resulting in an awkward situation, costing you a kill – or the game.
- Developed with inspiration from Abdisamad ‘SpawN’ Mohamed
- Two thumb buttons on both sides to comfortably serve left- or right-handed users
- Easy to switch between left- and right-hand functionality, no installation needed
- Optical encoder mouse wheel system for increased durability
- ZOWIE custom-designed lens for a very low lift-off distance = 1.5 ~ 1.8mm
- DPI (Dots Per Inch): 450/1150/2300
- Connector: USB
- Buttons: 5
- Length of cable: 2m / 6.6 ft
ORDER NOW
- Connector: USB
- Buttons: 5
ORDER NOW
DPI-adjustment
DID YOU KNOW?
ORDER NOW
DPI-adjustment
DID YOU KNOW?
ORDER NOW
- Connector: USB
- Buttons: 5
ORDER NOW
