Caporegime
- 18 Sep 2009
- Dormanstown.
read the thread
I did, you've just interpreted it differently (And wrongly)
read the thread
care to explain?
I'm not quite sure where you get that idea from.
i7 920 vs i7 2600k
Even the 2600k is more than 20% ahead of the i7 920 in allot of those benchmarks
i7 920 vs i7 3770k
The 3770k just extends this lead, so the Haswell i7 will probably be knocking on to being 40/50% faster than the i7 920 at stock.
Don't forget the Sandy and Ivy i7's clock higher than the old i7 920 do as well.
here. says its 50% faster lol
So is it 20% faster clock for clock?
Haswell should be, but I'm guessing, Ivy's about 15%.
But then it clocks higher, so as said, you could get upwards of 40% core for core over a 4GHZ 920.
But for all I know, Haswell can open up more overclocking potential to make it 45% core for core.
i dont care about OC potential i care about clock for clock speeds at present.
if haswell is 15% faster then Ivy, does that mean Ivy was only 5% faster then my 920 clock for clock?
Aim low and avoid disappointment.
Same boat as me, 4770k will be on the cards.
Count me in for that too![]()
Me too most likely, depending on whether reports of them being "an overclockers dream" are true or not of course.
