So, is Windows 8 any good, or should I take my old hard drive and put Windows 7 on a new PC?
It's extremely easy to use (ask my not entirely PC literate fiancee). That said, if you have a Windows 7 licence to use, now you've missed the cheapest pricing it's arguable if it's worth moving. On mechanical drives, probably not. On an SSD, definitely.
Any Windows is easy to use its not rocket science ,not like the old DOS days where you had to learn a thing or two,nowadays its too easy but you still get people moaning etc...especially if a simple start button goes.
Win8 pricing wise I think OcUK still have it for under 45 quid http://www.overclockers.co.uk/showproduct.php?prodid=SW-150-MS&groupid=33&catid=1555
So, should I take my old hard drive out, and then do the upgrade thing?
You can do an upgrade straight from the Win8 disc without removing the HD,it has options do to a clean install or keep stuff etc...
This guide is useful.
http://www.techrepublic.com/blog/wi...-guide-to-a-windows-8-clean-installation/6881 .
I know, but I'm going to put my hard drive in my new PC, hopefully.
1. Run the registry editor (regedit)
2. Find the following key: HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Setup\OOBE
3. Change the value for 'MediaBootInstall' from 1 to 0
4. Open an elevated command prompt (run as admin)
5. Run the following command: slmgr -rearm
6. Reboot
Thanks for that Elevon.
I need to reinstall Windows 8 on a clean drive (new SSD) shortly and I remembered I had the same upgrade problem with windows 7 on a clean hdd.
That work around of resetting the install media will save me some headache.
There is a app that lets you have your start menu back. Can't remember what it's called though. :/
