** Enermax Liquid Coolers - Pre Order Now **
rjk
rjk
OcUK Staff
8 Aug 2007
Hi Guys
I am pleased to announce today our pre order offerings for the Enermax coolers
these liquid coolers are a great addition to our range and come with a range of great performance fan options from Enermax that offer great performance over other market offerings.
The range is due to land at the start of next month :)
Enermax ELC120-TA Liquid Cooler with 2x T.B.Apollish Blue 12cm Fans (Socket 775 / 1155 / 1156 / 1366 / 2011 / AM2 / AM2+ / AM3 / FM1 / FM2) @ £76.99 inc VAT
Maintenance-free Cooling System
All-in-One liquid CPU cooler with pre-filled coolant offers best usability and maximum cooling performance for powerful PC systems.
Tri-Cooling Mode
High-performance PWM fans with innovative speed range switch for an individual RPM according to the system requirements: Silent Mode (800-1,500 RPM), Performance Mode (800-1,800 RPM) & Overclock Mode (800-2,200 RPM).
Long-Life Pump
Pump with durable ceramic bearing for reliable and noise-less performance.
Flexible & Robust Tubes
High-quality tubes made of FEP (Fluorinated Ethylene Propylene) guarantee non-permeable and long-lasting operation.
Easy & Universal Mounting System
User-friendly and quick mounting system giving perfect contact force with the CPU. Full support of all latest AMD® and Intel® sockets.
1x Liquid CPU Cooler ELC120-TA/-TB
2x T.B.Apollish blue 12cm fans (only ELC120-TA)
2x T.B.Silence 12cm fans (only ELC120-TB)
1x Intel® CPU Bracket
1x AMD® CPU Bracket
1x Back Plate
4x Back Plate Nut
4x Bracket Screw
4x Bracket Screw for Intel® LGA 2011 socket
8x Fan Screw
4x Case Screw
8x Rubber Pads
1x Installation Guide
Only £76.99 inc VAT.
ORDER NOW
Enermax ELC120-TB Liquid Cooler with 2x T.B.Silence 12cm Fans (Socket 775 / 1155 / 1156 / 1366 / 2011 / AM2 / AM2+ / AM3 / FM1 / FM2) @ £76.99 inc VAT
Tri-Cooling Mode
Long-Life Pump
1x AMD® CPU Bracket
1x Back Plate
4x Back Plate Nut
4x Bracket Screw
8x Fan Screw
4x Case Screw
8x Rubber Pads
ORDER NOW
Enermax ELC240 with 2x T.B.Silence 12cm Fans (Socket 775 / 1155 / 1156 / 1366 / 2011 / AM2 / AM2+ / AM3 / FM1 / FM2) @ £89.99 inc VAT
Tri-Cooling Mode
Long-Life Pump
1x Liquid CPU Cooler ELC240
1x AMD® CPU Bracket
1x Back Plate
4x Back Plate Nut
4x Bracket Screw
8x Fan Screw
8x Case Screw
8x Rubber Pad
Only £89.99 inc VAT.
ORDER NOW
the fans are what make these coolers great. really controllable and impressive performance figures.
Enermax have really thought about what specs they need to get the best out of these units.
check out the specs for the single fan units, brilliant!
As mentioned the units are similar.
Enermax use a different cooling plate and their fans are a big step up from other offerings.
