- 31 May 2009
He is missing his penis.
Forgot to include these ones, dunno how as they're two of my favourites.
All of them have been drawn on a samsung galaxy note 10.1 tablet using an app called autodesk sketchbook pro. The autodesk software is used in a few mainstream games, like borderlands 2, which is what got me started in the first place![]()
Sorry mate but I have to say this, I'm really not a fan of paint overs. You're really not teaching yourself anything. There seems to be a growing trend of people doing this right now, especially painting suicide girls. People should be stating what original image they used.
The incredible hulk is a direct paint over of a cg model. In a way the original artist should be referenced.
http://jonas.cgsociety.org/gallery/633803/
Spiderman was as it was the first image i'd ever done, painting over taught me a lot about the brushes and how the program worked. Hulk wasn't aside from the basic outline of the shoulders and position of the chin. Iron man outline was copied but all details and shading were added freehand. The rest are not. If it was a direct paint over for the entire image then fine, i can see your point. But it wasn't.
You're painting over someone's hard work and not referencing it, simple as. Use it as inspiration but don't pass it off as your own please.
The hulk is a direct paint over, it aligns perfectly in PS and you can see it by the eye anyways. It's a bad habit to start with, PS is just a tool and the real work is in the understanding.
Paint overs really irritate me, sorry!
Good thing about observation painting or portraits is it's easy on the creative mind but you can learn a lot by just looking...
