SSD died- which one to replace with?
2 Aug 2010
Egypt/ Surrey
I have been using a Kingston model (can't remember which off top of my head 120gb one)
I need a new SSD £2-300 which would you recommend for windows and apps etc? buying tonight hopefully
sorry mods- realised I should have put this into storage section-
ok thanks.
While your here any SSD you would recommend for the <£100 range for my LAN build (will be the only drive for os and games
Thanks Braka I won't forget that!
Cheers for your help Idleman!
Thanks RHS I will have think about the above
Yeah your right 128 would do, more the merrier I reckon though!
Thanks scotteh
