- 8 Sep 2003
- Was 150 yds from OCUK - now 0.5 mile; they moved
Hi guys!
I have secured a deal on the Logitech G110 Keyboard, enabling OcUK to offer the best price in the UK at under £50. Strickly limited to only 200 units, grab one before they run out!
To celebrate here are a few gif's.
Logitech G110 Illuminated Gaming Keyboard (920-002241) @ £49.99 inc VAT
Ready to step up your game? The Logitech® Gaming Keyboard G110 gives you what you need to customise your setup, communicate more effectively and execute complex commands easily. Locate the correct keys – even in the dark – with backlighting colours you can select and assign. Strategise with teammates and trash-talk enemies using the integrated USB audio. Configure up to 36 single keypresses or complex macros per game on the programmable G-keys. Use the MR key to record new macros on the fly. Connect your gaming mouse or flash drive to the Hi-Speed USB 2.0 hub port. Your game won't be interrupted until you're ready to call it quits, by disabling the Windows Context Menu keys with the game/desktop mode switch.
- Custom Colour backlighting
- Intergrated USB audio with seperate headphone and microphone jacks
- Twelve programmable G-keys with 3 macros per key
- High Speed USB 2.0 Hub built in
- Enable/Disable Windows/Context Menu Buttons with the flick of a switch
- Windows XP / Windows Vista / Windows 7 Compatable
- Removable Palm Rest
- Intelligent Cable Management
- One Touch Media Controls including volume control
- 2 Year Limited Warranty
Was £64.99 Inc. VAT
Only £49.99 inc VAT.
ORDER NOW
Was £64.99 Inc. VAT
ORDER NOW
