wasnt there a tool to do it ? from samsung?
there's definily one on HTC - Which worked great from my dads iphone.#
Samsung may have one too - well they should do. OP needs to google
Thanks.
That doesn't seem too bad..... how long was the screen time spread out across?
I thought the screens were actually more PE to the previous tech. iirc the GS 4 screen is supposedly 20% more power efficient than the GS 3 screen...
On another topic, how many of you bothered to drain the battery fully on the first few cycles? Are there any downsides to just charging from say 18% again? (I'm struggling to drain the battery!)
Not the official way (pretty sure there is one but can't find it yet....) but it will do the job
*bump video*
Thx for that Nexus , I was about to sit down and start a long tapping session .
Now any ideas for I tunes ?
I'm stock soo far. It's too early for me to try custom roms. I hate bugs.
What are you using to monitor temps? And is your phone overheating in normal use or are you benchmarking a lot? Got a case on?
2 days i got about 3.5hrs on the gs4. Not really tested the One properly.
I think the tech is 20% more efficient but as its a bigger screen it cancels out. The Soc's are deffo juicier though.
but that sounds pretty good. Can't wait to see the exynos version battery life.
HTC One has a slow charging time as they want to look after the battery more as it's sealed.
Plus it is li-poly so shouldn't age as quickly as li-lion (in theory)What’s interesting however is that the charge curve gets the One to 85–90 percent under the normal 3 or so hours, it’s that last ten percent that takes forever.
Afternoon chaps,
Anyone got a good idea of how I can copy all my contacts over from my iphone to my GS4?
If there's a means of not doing it manually then that'd be awesome. Otherwise it's going to be a long afternoon.
It seems to work perfectly fine and I can't detect any display issues at all.
The only thing that is annoying me is that despite having Apex Launcher installed and working, I occasionally and quite randomly end up in TouchWiz after unlocking. Not sure why that's happening.
Samsung have just the software for you mate,its free and works brilliantly!
See here :
http://www.pocket-lint.com/news/116000-samsung-iphone-galaxy-s3-easy-phone-sync
Cheers for the heads up Mike!
End up using this in the end, worked perfectly!
http://www.samsung.com/us/smart-switch/
A few from Hyde Park![]()
