Don't worry, mine isn't perfect and is going to be replaced: http://i.imgur.com/417EHtF.jpg (green line going down the S.)
The GS 4 has a very small FOV, smaller than the GS 3.
@kona Great picture comparison there. Thanks for that![]()
Have you updated your firmware yet? I've looked around and a few people are saying they're getting constant pop-ups about unauthorized software once rooted again so I'm reluctant to do it.
For those that are waiting for it there's now a recovery that works for the i9505 (i.e. UK S4 variant). Just installed TWRP 2.5 recovery and currently taking a backup to my SD card![]()
You think that's small, try the full 13mp lol. Since 13mp is 4:3 on the gs4, it makes look every narrower.
Nexus18, that looks likw GSMArena's One vs S4 review? It looks like it's been re-written since those FOV images were captured http://www.gsmarena.com/samsung_galaxy_s4_vs_htc_one-review-913p8.php The didnt seem impressed with the One at all. They also have the S4 down as having the better low-light performance as well. Do you think they've been paid off?![]()
But yup, what they said there is true, no denying, the GS 4 is better when it comes to zooming/cropping and bright light landscape conditions, however, what about other low light/dark conditions, macro shots etc.??? Their supposed "low light" test is crap.Main advantages of the GS 4 camera are;
- if you crop/zoom in on images, have a very high res. display and/or print photos on large paper.
- Bright landscape conditions
- panorama shots
- features/options overall
Main advantages of the one camera:
- very fast shutter and combined with OIS, you get more consistent/usable photos, more so in lower light conditions and/or with movement shots
- indoor conditions, low light/dark conditions
- larger FOV
- audio recording (really amazing in loud environments) and video recording overall (GS 4 looks excellent for 1080P recording but the OIS, FOV [which is further reduced on the gs4 when you enable image stabilisation] etc. give the one the edge by quite a bit imo)
The GS 4 can perform superbly in low light/night conditions with "night" mode (in some even better than the one) but it comes at a cost, slower shutter (iirc Brian said it takes about 2-3 seconds to process the shot) thus only useful with non moving objects and you need to have a steady hand (a lot of review sites use a tripod thus the GS 4 night shots in the majority of reviews look amazing and you don't experience the blur/shot latency etc. but in real world usage you might have to take the shot 3 times in order to get a good result)
Regarding the features/options, both seem to be more or less the same, GS 4 has the edge with a few more things to choose from. Most of the one's features are tied to the zoe feature and gallery i.e. sequence/drama shot, always smiling, eraser/removing objects etc. where as the features on the GS 4 are selectable through the camera app.
Macro shots look superb on both, need to see more from the GS 4, personally I think the one macro shots have the edge as they just have a very "natural" look to them and capture an insane amount of detail
Up to the end user this part, but photo size is quite different due to the difference in MP, talking about 1.5MP on average for the one VS 6.5MB for a photo from the GS 4
which varies with each device depending on the scenario i.e. buildings look too yellow on the one. The one I personally think produces more natural colours on the whole, however, some shots do look washed out but this can be fixed/improved by putting the saturation or contrast up by one level or just use auto enhance in the gallery.cheers mate, not a proper scientific test just a quick comparison. All 3 phones are great, each quite different and will suit different people.
Will hopefully get more pics up when I can. Wish I had a load of free time - boo!
no updates available to me yet. Not rooted either. Will do it maybe next weekend. Should be very sure and stable by then.
Awesome news mate
which root method did you use?
if I wipe the screen with a cleaning cloth it seems to disappear, once your finger goes over it a few times the mark comes back. Appart from that everything seems to be ok, I've not noticed any smearing effects or red patches.Thanks, so it is £429 for the handset in total and £22 pm for the line rental?
Best deal over 12 months is with phones4u on vodafone: £160 for the handset and £39 pm line rental and £100 cashback with quidco, dont use many mins or data (just emails) mainly wifi...
