- 8 Sep 2003
- Was 150 yds from OCUK - now 0.5 mile; they moved
Hi guys!
Available now for pre-order! The new H630 Case from NZXT, they offer a new great style from the famous NZXT manufacturer!
NZXT H630 Silent Ultra Enthusiast Tower Case - White @ £129.95 inc VAT
Beautifully architected, the new H630 is designed for two primary purposes: provide enthusiasts the ability to build the highest performing systems while remaining audibly invisible. With its incredible ability to subdue component noise, games, videos, and music take center stage of the system’s experience.
To help combat contaminating noise pollution, the H630 brings its owner several innovations. The H630’s insides are lined with high-density sound dampening material while the front of the enclosure is the first of its kind to support twin 200mm large fans. With their size, the fans spin at a silent RPM while pushing large volumes of air. Meanwhile, vents are intelligently positioned to lower intake noise. The H630 also provides exceptional support for a wide range of cooling solutions, including the ability to install 240mm, 280mm, and 360mm radiators.
The H630 utilizes a closed-cell, high-density foam which is the most efficient solution for silent computing. With seven millimeters of this premium sound dampening solution, the H630 is capable of destroying component noise without hindering performance.
The H630 offers the best water cooling support of any silent chassis period – Capable of supporting a 360mm radiator in both the front and top positions without any modifications.
The H630 is the first chassis in history to support two 200mm fans in both the front and top positions. With fully modular hard drive cages, the H630 offers unrivaled airflow capabilities. Unlike much of its competition, the H630 offers maximum airflow expandability without the removal of any sound dampening material.
- Dimenions: 245 x 547 x 567mm
- Material: Steel / Plastic
- Motherboard Support: ATX / mITX / mATX / XL-ATX / EATX
- External connectors: 1 x Audio / 2 x USB2.0 / 2 x USB3.0 / SD Card Reader / LED on-off
- Bays: 2 x 5.25" External / 8 x 3.5" or 2.5" (2 behind MB tray)
- Front Cooling: 2 x 200mm ir 2 x 140mm or 3 x 120mm (1 x 200mm inclided)
- Top Cooling: 2 x 200m or 2 x 140mm
- Rear Cooling: 1 x 140mm or 1 x 120mm (1 x 140mm included)
- Bottom Cooling: 2 x 140mm or 2 x 120mm
- HDD Cooling: 2 x 140mm or 2 x 120mm
- Max CPU Cooler height: 190mm
- Max VGA Card length: 354mm
- Cable managment space: 27mm
- 2 Year Warranty
Only £129.95 inc VAT.
ORDER NOW
NZXT H630 Silent Ultra Enthusiast Tower Case - Matte Black @ £129.95 inc VAT
- 2 Year Warranty
ORDER NOW
- 2 Year Warranty
ORDER NOW
- 2 Year Warranty
ORDER NOW
