- 13 Apr 2010
- Sunny Sussex
Not really, it's not really 'fine' then as a retrofit then, is it?
When I was contemplating breaking the tourer the xenons were the first item to be stripped off but looking into it the kit that is included scattered around the car is immense, how does a retrofit kit work with self levelling?
Not really. The non-xenon projectors are like the e36 ones aren't they, there's a reflector around the outside of the lens
Grey with black leather?http://www.autotrader.co.uk/classif...page/1/radius/1500/postcode/de248qw?logcode=p
I'm loving the colour combo on that![]()
And the silver on the dash and round the gear stick
TyvmSo, one of the most common (and dullest) interior colour combos then.
Check your hotmail.[TW]Fox;24239103 said:I need to do that exact job![]()
Cinnamon is gorgeous.
Previous owner had already done this. I'll keep an eye on the area though.Did you pull out the rubber grommets on the underside of the thin strip between the boot and bumper for an inspection? I did when fitting my towbar and the edges were starting to rust up. Nip it in the bud with a rub, touch of paint and a squirt of waxoyl in the cavity.
