On another note im after some advice.
I snapped the rear seat stay on my Trek Fuel EX on a tiny drop off, Evans (got it on sale cheap) were difficult but i am expecting a replacement frame under warranty.
120mm travel is a little short so i was thinking of getting something else maybe around the 140-150mm.
Just because you snapped a frame doesn't mean you need a bike with more travel. It could have just been bad luck. **** happens. If you were regularly breaking stuff then maybe a burlier bike is what you need.
As above. The Alpine is probably too much bike. But it depends what you ride and how you ride it. Another option to consider is the Blur TR (alu).
