Guessing it's had a respray?
Look at how they join on past the door, they're not clip on ones, fairly big job to do it. Not just a case of spraying some originals in white and swopping them over, these were done when the car went in for the full respray.
Will check that thanks.
Loving the car so far though, engine is very impressive, can slip it into 5th at 30mph easily and it pulls well throughout the rev range on a more "spirited" drive. MPG isn't the best though, can just about make 30mpg on my 13 mile commute with a very light right foot and 50mpg cruise on the motorway stretch, average 20mpg on the way back due to more stop start with the traffic.
You may as well give Royal Steering Wheels a call and arrange that wheel to be chunkied up a bit! nothing worse than a thin steering wheel. It won't cost the Earth either, £105 for a re-trim.
30mpg on a 13 mile stretch? no you didn't, or you reset the trip whilst up to speed which completely defeats the point.
Good god no, that's a good standard steering wheel. Thin enough except for the thumb rest and controls, makes the handling and car feel better for me.
[TW]Fox;24281718 said:Not sure if serious.
Come on Fox, for £3k this would have been your choice surely?
[TW]Fox;24281743 said:No, not at all, sorry
It's an SE with random aftermarket sideskirts, a facelift bumper, blacked out headlights and a bizarre white spray job.
I really think with a bit more patience you could have done much better. If you are happy with it, great - but unfortunately it sets all my alarm bells off. I'd be particularly nervous of the reason behind the spray job. You'd need to really, really, really want it white to spend the money doing it to that car. Unless it already needed to a respray...
[TW]Fox;24281798 said:I thinK i'd probably get the wheels sprayed back into silver and the front/rear bumpers replaced with Sport ones, with those sideskirts replaced with Sport ones. Then the headlights for standard OEM ones.
Bingo - one white 330Ci Sport looking cab. It'd be a lot nicer looking then, IMHO.
Seats are different on sport models, they're a bit more comfortable and the front bit (where your knees are) can be extended to make them even more comfy.
