I got my batts from efest, but torchy the battery boy does some good deals on his ebay shop
Just a heads up for you guys, the Meshcompany has a side site designed for us vapers in mind, quite a bit easier to find what you want rather than trawling through the list.
Also as of the week commencing 20th May, a wide range of Ekowool and 316 Stainless Steel 7 x 19 and 7 x 7 wire rope will be available to purchase through http://www.vape-atomizer-mesh.com/
great stuff I found the site a mine field otherwise.
Hamster - Torchy Boy's batteries are good and he does discounts if you buy direct rather than going through ebay.
http://ukvapers.org/Thread-Torchy-battery-prices
Yup there isnt much difference in the ratings of Kanthal, its just the heat they can withstand, which in terms of vaping we never reach untill it shorts, for round wire A/A1 is the most prefered as it will last a little longer before it snaps but your never going to notice a difference.
Ribbon wire is D and most round wires are A/A1.
If you want cheap and you're happy taking any risk involved, buying from China will get you the cheapest Vamo. Vaporbreak are the cheapest I think. I got mine from Zainy.net for a few quid more. Read up on it before deciding; there's a thread somewhere on UKVapers about the £20 Vamos from Vaporbreak.
Thanks Knight. I was a bit undecided the other day. A was a lot cheaper but I went for the A1 as it seemed that's what everyone else was using. I'll probably get A next time.
Here's my new toy, sadly no batteries yet. Dying to try it out!
snip
It's in mini mode. I have small hands![]()
If you're in Manchester central you're more than welcome to borrow some batteries and a charger until yours arrives
Rather not get tacky stuff for cheap. But what are the chances ill be getting that from a UK based online site anyway?
can you post a pic of it and the top cap?
with a genesis you need to tilt your pv to get it wicking properly.
Thats about normal, ive had that in all the genesis ive coiled so far, RSST being the worst, AC9 being the cleanest after a days use, think its the thickness of the metal allowing to heat up and cool quicker compared to the AC9's thick steel.
im happy with my vamo and kanger protank, im not an electrician or a mechanic lol some of this stuff is a step too far for me lol
