Good work btw and good info. Nice to see user bench results rather than some questionable reviewers. I would trust these![]()
It's been great to see the progress AMD have been making with their drivers recently.
Sounds like they're going to remain the best GPUs to buy if the GTX 700 series is anything like the rumors are saying.
Crysis 3 is the first game ive seen that has brought my clocked 7970 to its knees at the highest settings at a res of 1440p. Everything else can be run at ultra with good fps providing you knock AA down a tad or in a couple of cases disable it completely. (farcry 3 and Tomb Raider)
FXAA can be safely run on all titles but i did disable it Crysis 3 though to be honest im not sure it made any difference to the fps.
I might actually run Hitman again and put AA at x2 as there is fps to spare on that bench. I might also retest Bioshock with DDOF enabled.
Tried metro LL ??
I don't own it, yet. I'll be getting it at some point. I heard that was a bit of a gpu killer as well. Although ive also heard that AMD performance has improved a lot since they released the game patch a few days back.
have you got the before driver and new ? to compare.
If I get chance I'll run some on 13.4 this week. Though I am considering selling up and starting from scratch soon![]()
Erm....? Matt, i'm looking at your game pre-sets "Tomb Raider - Ultra Preset - TressFX"
Your 7970 @ 1250 / 1823: has Tomb Raider 42 / 53 / 66. that's not right for "Ultra Preset - TressFX" I have just run it (13.4 testing) and got 40 / 54 / 68 with straight Ultra Preset - TressFX.
There is a setting, shadows, i think, that defaults to normal or high on Ultra Preset, did you have that turned up as its a good 25% or more.
In any case i think Ultra Preset as it is is probably a good idea as for those with a GTX 660 / 7850, the actual full settings will roll a slide show for them.
Perhaps run it again and update your chart?
Edit- no wait, 1440P... i'm running 1080P...lol
Complete new build ?![]()
Battlefield 3 - Ultra Preset MSAA x4 - FOV 80
Bioshock - Ultra Preset
Crysis 3 - Very High preset on system and texture - MSAA x0
Dirt Showdown - Ultra Preset - MSAA X4
Farcry 3 - Ultra Preset - MSAA x0 - FOV 80
Hitman - Ultra Preset - MSAA x0
Sleeping Dogs - Ultra Preset - SSAA High
New benchmark template
Old templates
