@chaparral - From that it looks like you haven't used it at all lol
Am Cheating as am still mainly using my S3.....You're obviously not using it enough![]()
If it is locked a code on ebay is only £8Can't find this info anywhere but are Vodafone upgrade S4's unlocked ? Just bought one off eBay and starting to panic as I'm on O2
The one I bought from ebay was unlocked, still voda branded though but a quick flash sorted that.
The latest stock pre rooted one from XDA, there's a thread with them in over there.
So are custom roms avaliable yet? Guessing you still can't move apps to sd card yet?
Surely the existence of this http://www.mobilefun.co.uk/genuine-samsung-galaxy-s4-wireless-charging-cover-white-p38584.htm suggests they're wrong about it having wireless charging built in?
Haven't looked through to see if there's been any replies about the neo hybrid and docks (I'll look later) but just thought I'd post this here quickly
http://cgi.ebay.co.uk/ws/eBayISAPI.dll?ViewItem&item=120598680485
What do you all think of that? The seller says it will work without any additional accessories as the S4 has a built in wireless receiver that will allow it to charge
It doesn't have one built in, hence why it needs the cover. It just has a connector. You can buy receivers that stick inside the existing cover.
See here
http://www.ebay.com/itm/261216364963
Thanks for the link
I assume these wireless chargers are fine to use, even these ones from Hong Kong ... Don't damage the battery or anything? Just charges slower than plugging it in?
Will still be fully charged over-night if left on there and stop charging when it needs to, right? Silly question I know
(As I find my S3 is better then my new S4)![]()
