- 8 Sep 2003
- Was 150 yds from OCUK - now 0.5 mile; they moved
Hi guys.
We have the new Gen.2 Corsair pre-braided PSU cable kits coming into stock the end of this week. Pre-orders are now available.
Corsair Generation 2 Sleeved Cable Kit (AXi / AX / HX / TXM) - Black @ £64.99 inc VAT
Customize your system build with Corsair Professional Series cable upgrade kits. New triple weave design and all black heat-shrinks will give your build a clean, professional look and feel. Improved flexibility provides ease of use and installation. Cables kits available in six color options to give you the freedom to customize your build to your style.
- Individually Sleeved Modular Cables
- Improved flexibility for ease of use and installation.
- All Black Heat-Shrinks.
- Improved High-Density Triple Weave Sleeve Design
- Multiple Corsair PSU compatibility
Corsair PSU Compatibility
- AXI Platinum Series - 1200/860/760
- AX Platinum Series - 860/760
- HX Gold Series - 1050/850/750/650
- TXM Bronze Series - 850/750/650/550
- CXM Bronze Series - 750/600/500/430
Only £64.99 inc VAT.
ORDER NOW
Corsair Generation 2 Sleeved Cable Kit (AXi / AX / HX / TXM) - Blue @ £64.99 inc VAT
- CXM Bronze Series ¡V 750/600/500/430
ORDER NOW
Corsair Generation 2 Sleeved Cable Kit (AXi / AX / HX / TXM) - Metallic Graphite @ £64.99 inc VAT
ORDER NOW
Corsair Generation 2 Sleeved Cable Kit (AXi / AX / HX / TXM) - Green @ £64.99 inc VAT
ORDER NOW
Corsair Generation 2 Sleeved Cable Kit (AXi / AX / HX / TXM) - Red @ £64.99 inc VAT
ORDER NOW
Corsair Generation 2 Sleeved Cable Kit (AXi / AX / HX / TXM) - White @ £64.99 inc VAT
ORDER NOW
Corsair Generation 2 Sleeved 24 Pin Cable (AX) - Black @ £14.99 inc VAT
- Individually Sleeved 24pin ATX Cable
Box Contents
- 1x 24pin ATX Individually Sleeved Cable (610mm)
Only £14.99 inc VAT.
ORDER NOW
Corsair Generation 2 Sleeved 24 Pin Cable (AX) - Blue @ £14.99 inc VAT
Box Contents
ORDER NOW
Corsair Generation 2 Sleeved 24 Pin Cable (AX) - Green @ £14.99 inc VAT
Box Contents
ORDER NOW
Corsair Generation 2 Sleeved 24 Pin Cable (AX) - Red @ £14.99 inc VAT
Box Contents
ORDER NOW
Corsair Generation 2 Sleeved 24 Pin Cable (AX) - White @ £14.99 inc VAT
Box Contents
ORDER NOW
Corsair Generation 2 Sleeved 24 Pin Cable (AX) - Metallic Graphite @ £14.99 inc VAT
Box Contents
ORDER NOW
Corsair Generation 2 Sleeved 24 Pin Cable (AXi) - Metallic Graphite @ £14.99 inc VAT
Box Contents
ORDER NOW
Corsair Generation 2 Sleeved 24 Pin Cable (AXi) - Black @ £14.99 inc VAT
Box Contents
ORDER NOW
Corsair Generation 2 Sleeved 24 Pin Cable (AXi) - Green @ £14.99 inc VAT
Box Contents
ORDER NOW
Corsair Generation 2 Sleeved 24 Pin Cable (AXi) - Red @ £14.99 inc VAT
Box Contents
ORDER NOW
Corsair Generation 2 Sleeved 24 Pin Cable (AXi) - Blue @ £14.99 inc VAT
Box Contents
ORDER NOW
Corsair Generation 2 Sleeved 24 Pin Cable (AXi) - White @ £14.99 inc VAT
Box Contents
ORDER NOW
ORDER NOW
ORDER NOW
ORDER NOW
ORDER NOW
ORDER NOW
ORDER NOW
Box Contents
ORDER NOW
Box Contents
ORDER NOW
Box Contents
ORDER NOW
Box Contents
ORDER NOW
Box Contents
ORDER NOW
Box Contents
ORDER NOW
Box Contents
ORDER NOW
Box Contents
ORDER NOW
Box Contents
ORDER NOW
Box Contents
ORDER NOW
Box Contents
ORDER NOW
Box Contents
ORDER NOW
