*** The Official Samsung Galaxy S4 Thread ***
Anyone having any signal issues. Noticed yesterday (after getting an email saying my phone is off) that i keep losing signal. (no signal bars) it doesn't say no network coverage just no signal bars in the triangle. But I am unreachable.
If i try to make a call it kicks back in and the signal comes back. But no-one can reach me until then.
I've just switched to GSM mode to see if its the same
Stock ROM?
That would be faulty - sorry bud.
Mine is all uniform white.
S4 #2 arrived today, putting them side by side it was even more obvious how much of a red/pink tint the bottom half of the screen had when viewed on white/grey backgrounds. I also noticed that the screen is slightly more raised on the left side against the bezel/trim when compared to the second phone.
Must've been made on a Friday at 4:59pm that one :P
Result!
Just don't tell Jono8 you have a pukka one :D
I updated to the new EE firmware (I have an EE S4) and since then the phone has completely changed. I can't write emails properly due to an issue with Swiftkey and I have noticed a massive dip in reception performance, it either doesn't register on EE or stays on GPRS...
I have since downgraded the software and the modem to the previous version and since it seems to be fine.
Mines fine since switching to GSM only.
Luckily I work from home. So am mostly on wifi
Might be worth getting hold of a modem fw file and flashing that just in case something's gone a bit nuts with the copy already on your phone.
That may be a little beyond me.
I have found a similar issue on XDA so have posted on someones thread over there. See if anyone has an easy fix.
Kona,
Have you got your card yet? Mines been despatched today so it look like you were right about delivery tomorrow :p
Indeed I have :cool:
