Great work by the pilots. Sadly it may detrimentally affect their career long term. I seem to recall that the pilot who landed at Heathrow or gatwick a few years ago due to ice on the wings was later made redundant. He was then turned down from a number of airlines as he had an accident on his record; despite the fact the emergency landing wasn't his fault and he flew heroically to save everyone.
Been following this on various forums today and this is probably the best account so far..
http://avherald.com/h?article=462beb5e&opt=0
Not much of a story really. Plane hits birds, safety procedures work correctly, plane lands, a bunch of flights delayed/cancelled.
He took redundancy and is back flying with BA. He also didn't land the aircraft.
A bus with an engine out is no big deal. I'm sure Blinkz can come in here and tell you that. The extra crew load is tiny compared to other failures and how engine failures used to impact crew attention. It's really not that heroic at all. It would have been more worrying that the fan cowls could have damaged the airframe.
So it looks like the ground crew messed up and the pilots should have checked the cowl latches during their pre-flight check?
In this instance the crew were dealing with an engine out, low confidence in the remaining engine, a fuel leak and difficulties with the hydraulics. Quite a big deal!
Is there a confirmed engine out? In the landing video the port engine has thrust reverser actuation and as far as I understand, this will not happen on an Airbus if the engine master switches are turned off (as they would be in an engine shut down). The starboard still seems to be in action given the trail from it as seen in videos on news sites.
What difficulties with the hydraulics? Single engine operations on the 319 is a piece of ****. I'm sure the stress level was up but the actual operation is no harder on the crews than dual engine operation.
