Spec:
Big Spec List
Looks like a well sorted car, must say I am somewhat surprised its running on standards injectors with that sort of power.
EDIT
Ignore I read it as 250hp
Spec:
Big Spec List
AD08's are superb in the dry but they're useless in the wet and cold weather. I wouldn't use them again on an everyday car.
Important Care And Usage Instructions:
The ADVAN Neova AD08 was developed using high performance compounds which become brittle at low temperatures and therefore should not be used in certain conditions. ADVAN Neova AD08 tyres thus must be stored or used only at temperature at or above -10°C (14°F) to maintain performance characteristics and to avoid any damage to the tyre or injury to persons or property.
Never had any issues with them on my car.
"I'd take a set of T1-R's over AD08's". Said no one, ever.
You may never have any issues but the wet weather performance is poor which is backed up by tests. The biggest thing for me though (I've experienced it) is the chance of aquaplaning when hitting standing water being too high for my liking, something purely down to the tread pattern. For that reason alone I wouldn't run them on an everyday car again. Amazing in the dry though and the sidewalls seem spot on to.
Oh not again
You've got a cracking car there with some serious BOOST, stop cheaping out with rubbish tyres. I'm not advocating slicks as a bit of slide is fun IME. Full set of Bridgestone RE002 was £266 in 195/50/15. Much better.
So you never actually had a bad experience with them but are going off internet hyperbole?
They are labelled grade A or B for wet.
