Road Cycling Essentials
Status
Not open for further replies.
It's a sportive, there'll be something like 600 other people to ride with.
Go and get on your bike and stop the excuses :p
:p
It's more the lift I'm arsed about. I'll more than likely end up going if I can badger the Mrs into taking me. I'm just having a moan. :)
Not the most interesting Strava challenge but better than nothing - they should definitely do an elevation one at some point. Another good option would be a challenge to ride as many 100km/100mi rides in a month as possible rather than just cumulative distance.
I want an elevation challenge. Much more realistic for me than distance.
[Damien];24360592 said:
Elevation challenges are definitely needed.
That won't be far for people with miles and miles of flats... Lucky for me, I have the best of both worlds.
I'm setting myself to do 200miles this June. It's not a lot but realistically a weekly 50miles should be possible. Or if one of the weekend shows to be a nice day, I might cycle even longer!
You'd be surprised how much climbing the guys living in 'flat' areas end up with. It's not the same as the climbing that you will have where you live, with big climbs but the constant little ups and downs over a long distance add up.
30 hours in two weeks? Not a chance.
I think I'm going to miss the 500k mark this month, due to the late surge of bad weather, so I'll have to start solidly in June to make it next month.
was easily going to tick over 600k this month but felt ill :| so ill ride ~60ish km till end of may and end bang on 600k..
I am currently in a bid war, sniping a local 17" racer with 24" wheels. The seller is selling it as a childs bike but I sincerely believe it'll fit my missus. Looks great and upgrading the wheels to 700c seems like a possibility.
Have anyone got any experience with doing something similar? It's a 5 speed Centurion bike, with SASCHS HURET derailer. Now, does that mean whatever I do, unless I upgrade the derailer, I can only stick with 5 speed cassets?
Difficult to get a picture when I'm playing with bikes in the living room, er, where I'm not really supposed to be doing it :p
Properly tight clearances on this. You can only just get your fingers between the front wheel and the frame and it's only wearing 23s :eek:
So what the seller failed to tell me was that the stem bolt is rounded out and the stem is cracked :rolleyes:. The good news is it's a 22mm steerer, which is standard quill size. I haven't had the bottom bracket out, but it's a 70mm wide shell and the bb is 108mm wide, so that's why it looks so narrow. I'll need to run a 110 to get a correct chainline with my crankset, so I'll probably use a threadless one rather than try to change the threads.
Other specs are pretty much meaningless, because it's all Ruskie spec :p
[Damien];24360665 said:
:p
Pre-race nerves! I am doing Le-Terrier this weekend and also am reaching that stage where I wish I hadn't said I would do it :) 8000ft of climbing in 66 miles :(
I think so, though I don't think you can get 5 speed cassettes; you are in the world of 5 speed freehubs that screw onto the hub. The hub body doesn't include a freehub. It's also probably a 126 OLN separation as opposed to modern 130mm. That's not a problem for a steel frame (unless it's Reynolds 753 or equivalent).
Being 5 speed it will be friction shifters on the down tube rather than indexed so provided a 6 or 7 speed free hub is the same size as a 5 speed it may well be possible.
Hmmm. I need to do some research....
128km to go to reach the magic 1000km for May. I'm tempted to squeeze in 20 miles after football tomorrow night then take the afternoon off for a 60 miler on Friday. So close but yet so far...
Been off work last two days and don't think i'll be back tomorrow so will be missing out on the 1000km mark, 827 so far, will try to get 900 if I'm better on Friday! June going to be a monster month though, 2 weeks off, although I will be going to the dark side and doing more on the mtb than the road if the weather improves.
If the stem is knackered already, just take a hacksaw* through it above the headset. Get a punch and knock the rest of it out the bottom.
*Or, in true Johnny69 style, an industrial-size, petrol powered angle grinder (still in the living room). :p
I am nervous as I understand the bike can take 700cc wheels, and so need to cost in wheels and stick with a 5 speed Sunwin cassettes (~£50 for wheels and 5 speed freewheel + tyres)
If it's all I need then budget for the bike works. If I need a new derailer, then bummer... :eek:
Everything is so green to me!
24inch wheels are tiny compared to 700c wheels. Are you sure they will fit? Have you got any pictures of it?
Got more info now, its standing height of 28", same as my missus inside legs. Will need to increase the post and stem as it's 18" from crank to seat.
Yes, 24" wheels is likely to be too small - will risk it and get it. There's 650c or 700c wheels to help up it? Still sniping so lets hope I get it under a budget I have in mind.
Worst case scenario, I get a kiddie road bike I'll need to pawn off to a local club.
Status
