I've been running a Zee Rear mech with an XT 11-36 cassette with my 1x10 setup for a few rides now. Not much to report other than it works superbly and shifting is great. No chain slap at all. Nice and quiet and tight with the clutch. I run it with an XTR shifter.
I see talking above of chain retention and the possibility of running without a guide with the new clutch type rear derailleurs. Have you all seen/heard of the new chainrings that are all coming to market right about now? It seems SRAM's XX1 (bespoke BCD) chainring is basically being copied and brought to market by other manufacturers at a much lower price point and common sizes including SRAM direct mount and 104 BCD.
The "technology" that offers superior chain retention on these chainrings, is the tooth spacing and shape. It's not so much the height of the teeth, but the width of them. Every other tooth is wide. So it goes wide then thin then wide and so on. This helps grip the chain. It grips it so well, one manufacturer (absoluteblack) claims it so good that they have pictured a chainring in mid air with a water bottle hanging off of it and it is being held only by the friction of a piece of 10spd chain a few links long.
SRAM XX1 was based on studies into the chain coming off the ring in slow motion, noticing that it was mainly side to side movement that caused a dropped chain. The aim is to prevent this.
There are a few more indy outfits making these rings including a couple in the USA.
Absolute Black (posts on some mtb forums)
Wolftooth (posts on some mtb forums)
MRP (rumour?)
Raceface
Works Components (UK but do not respond to email and items out of stock)
NSB
The most promising of the above for us UK folk, is RaceFace, mainly because Wiggle.co.uk currently lists the chainrings as a purchasable item but shows them as due late June. I have spoken to silverfish the UK supplier for RaceFace and they confirm wiggle may be the first place to get these in stock.
Wear rate is the only concern with these. Some people have said that XX1 wears quickly and with wear comes less chain retention. This however, is true with any chainring and is only really an issue if you start to depend on it for chain retention solely. These new wide/thin chainrings will start to replace single ring chainrings in time, as every manufacturer produces them with the same technology built in. At the end of the day, why wouldn't you? Already it looks like the RaceFace ones will be priced in line with normal single ring chainrings anyway... I say normal... £40 ish, so at the top end of the market, but no more than a hope Single ring, and a little more than say an E-Thirteen.
I think these chainrings paired with a clutch type rear mech is the future of 1x10 setups and will see a lot of people be able to ditch a guide all together. Already on other forums people have been running them with success over very rought terrain. In terms of wear, pro test riders have seen dropped chains due to wear after extensive testing (and I mean a LOT of riding like as a day job) which to the average rider who goes out for a once or twice a week, would still not see any issues for 6-12 months as a prediction from one of the above manufacturers. But then....they would say that.
Other criticism I have seen is possibility for chain suck, but nobody has reported issues with this in practice from the threads I have read. Again, the manufacturers say this will not be a problem.
