 - 10 Nov 2006
 - Lincolnshire
So I unlocked afterburner using the cfg file, my overclocks and everything work perfectly but I get screen flicker.
I googled this and found another way of unlocking it so I put the cfg back to standard and used the rename of file properties on the shortcut instead (-xcl).
This stops the screen flicker but creates half a dozen more problems, GPU-Z is now next to useless using this fix, showing the first GPU being stuck at the last overclock even when applying a new one or rebooting (2nd GPU is fine). The sensors don’t respond including core and memory.
This also for some reason appears to unlock CCC as well (this is not a big problem as I use afterburner).
The only way so far I’ve found on fixing these problems is to uninstall afterburner and ATI drivers and starting again.
Can any-one help me to use afterburner unlocked without any of the above problems
