Another haswell spec needed: £1250
21 Jul 2005
Hi Guys,
Posted a couple of weeks back asking for spec advice and everybody said wait until Haswell, my budget is £1250. I need:
Graphics
Ram, board, cpu
Nice sound card
Nice case
power sup
ssd
I don't plan on overclocking much, I do a lot of image editing and some gaming.
Many thanks!
Thanks stulid. Yes I already have some drives. Do you think 550w its big enough for the psu? also what is the main difference between i7 and i5 chips?
The 550W PSU is enough for that spec, it is a quality PSU too.
Heres a slightly stronger PSU for a bit more - http://www.overclockers.co.uk/showproduct.php?prodid=CA-230-SV&groupid=701&catid=123&subcat=2283
Both PSU's are modular too, so you don't have to worry about unused cables being hidden away.
i7 CPU's have Hyperthreading mainly so you have 8 threads, i5 has four.
last one, what is the main difference between the ram ratings on the ddr3 listed in the shop? I know they are overclocking related but is there any real world difference in mild overclocking scenarios? for example:
DDR3 Dual-Channel - PC3-14400+ vs DDR3 Dual-Channel - PC3-12800
I reckon if you want RAM to be running at a certain speed, then buy RAM rated at that speed.
Not all RAM clocks well, so you may buy a 1600MHz kit and be disappointed if it wont go higher.
I went for this in the end, hope its ok and I've already hit the trigger on it, thanks for all the help
Gigabyte GeForce GTX 770 WindForce 3x OC 2048MB GDDR5 PCI-Express Graphics Card (GV-N770OC-2GD) £304.99 1 £304.99
Intel Core i7-4770 3.40GHz (Haswell) Socket LGA1150 Processor - Retail with FREE Grid 2 PC Game £208.29 1 £208.29
Toshiba SSD HG5D Series 7mm 256GB Solid State Hard Drive - (THNSNH256GCST) £141.66 1 £141.66
OcUK Tech Labs - Anidees AI-6B Midi-Tower Case - Black - Noise Dampened £94.99 1 £94.99
Gigabyte Z87-D3HP Intel Z87 (Socket 1150) DDR3 ATX Motherboard + FREE Be Quiet! Shadow Rock Pro SR1 CPU Cooler! £91.66 1 £91.66
Patriot Viper "Black Mamba" Generation 3 16GB (2x8GB) DDR3 PC3-12800C9 1600MHz Dual Channel kit (PV316G160C9K) £84.99 1 £84.99
XFX 750W XXX Edition Modular '80 Plus Silver' Power Supply £74.99 1 £74.99
Creative Sound Blaster Z High Performance Gaming Sound Card - OEM (30SB150200000) £44.99 1 £44.99
Arctic Silver 5 Thermal Compound (3.5g) £7.49 1 £7.49
Akasa AK-MX002 PSU and Fan Noise reduction Kit £3.32 1 £3.32
GRID 2 PC Game - FREE with Haswell CPU's, Systems & Bundles £0.00 1 £0.00
FREE SHIPPING (DPD Next Day): £0.00
VAT: £211.47
Order Total: £1268.84
VAT: £211.47
The CPU is not the "K" version.
The PSU is enough for two GFX cards, but the board isnt.
