- 25 Sep 2009
- Billericay, UK
The plan is to nail varnish the resistors although they are 5mm away from the die and then liquid pro the lid back on.
I think haswell just generates a lot of heat. If goes from under locked and 25C at idle to 100c within seconds. Let's hope is not the future.
Sadly it is, i can't remember the exact reason but Intel can't use solder on the die because of the 3d trigate transistors. If they don't find a round this then going forwards I might not bother with overclocking, theres no real benefit to it in games and more and more programmes can be accelerated by the gpu.
