And I say again...
both will do the job, both are rated highly but i see people recommending the gp4000's more than gatorskins ?! haven't tried either but im sure you can't go wrong with either one of them!
Much of a much-ness. Do they have to match?
On both my bikes I run a 23C gp4000 up front as I have literally never had a front puncture.
Then one bike runs a 25c 4seasons and the other a 25c gatorskin. Most weight is on the rear so I find it helps with puncture protection, rolling resistance, grip and ride quality.
Gatorskins have better puncture resistance and are cheaper. Their wet performance is a bit sketchy though compared to the GP4000s.
Don't be afraid to pull it quite tight as you're wrapping, that tends to make life easier.
Everything about the GP4000s sounds ok from black chilli to the vectrem puncture resistance which is supposedly tough than steel...
Any more opinions from people?
Excellent work, uniQ. That is a truly excellent pace to maintain over that duration, too. What food did you eat while on the bike?
If you're doing an endurance type event then I'd say wet performance isn't a massive issue unless you're planning to hammer round or do lots of quick descending. You'll probably not be going quick enough to push tyres to their limits.
As for being tougher than steel, if they were then no-one would ever get a puncture.
uniQ - chapeau Sir, that is amazing. A metric double is my next target but an imperial double is still a WTF amount of miles!
They're great tyres but I'd personally recommend going for 25c as they're a bit more comfortable and roll slightly better. The difference in aero performance isn't likely to be an issue for a normal rider.
