- 13 Jan 2004
- Leicestershire
Wow!!! Hard core!!
That would petrify me solo being a newbie!!
Max rpm 205!!!
Wow!!! Hard core!!
Max rpm 205!!!![]()
[DOD]Asprilla;24420547 said:They can be tougher than steel but its a woven fabric so things can penetrate between the threads. Thread density is equally important.
Road rims traditionally only come in one width (though that is changing now) and you can have from 20-28mm tyres on them, probably as high as 35mm for cyclocross.
[DOD]Asprilla;24421133 said:Swissstop green or blue or Koolstop salmon.
They are listed as wet pads, but they are still the best for dry conditions and are soft so they preserve your rims.
Finished dragon ride. A slightly disappointing 9hrs50 - stopped off way too many times and burnt out during the penultimate climb. Wasn't helped by my mate who had no idea of pacing and just went for every hill!!
[DOD]Asprilla;24422238 said:Good work fella.
That means you've got a benchmark to beat next year. How did you find the Rhingos and B'wch?
[Damien];24415983 said:Yeah it's the fizik performance stuff I've got. The problem is that apart from it being super thick, it's got a very defined pattern on it. It's got a flattish perforated bit about a third of the way across, then a raised bump bit, then a flat fizik logoed bit. That means you don't really have much leeway to vary the overlap. Also because of the thickness it likes to go baggy on the top edge as you tighten the bottom edge.
