Road Cycling Essentials
Status
Not open for further replies.
Had a go with the Fizik Performance tape i got a month or so back.
Not bad. You seem to have wrapped it the opposite way to me though. I overlapped it so the fizik logo was covered and the perforated bit was showing. It looks like you've done the opposite.
I could probably get it neater (it went through several wrap/unwraps until I was happy, plus I cut diagonally the wrong way to finish on one side) but I'm satisfied considering it was the first one I've done.
A few pictures from saturdays sportive. No cheeky grins this time :D
Nice one Minty! Shame I couldn't join you. The weather was perfect for it! :D
Looks fine to me!
You had me worried there, i've done a bit of searching ref the way round i've wrapped it and there isnt much but someone had posted a review saying it could be done either way round so i'm happy at least someone else thinks thats the case. :D
Looks and feels fine to me anyway.
I've had some of that Fizik tape for about a month now waiting to be used, but the bars I ordered at the same time still haven't arrived!
I bought the Fizik tape to match my Fizik saddle, but I've since changed saddle to a Specialized Toupe :p
Is yours the Soft Touch White or normal White Damien?
It's the soft touch. For some reason the start and end of the roll has a completely blank bit with no pattern or logo on. I cut both flat ends off as it looked stupid as part of the wrap. You have to be very conscious of how you wrap it though to be sure you've got enough to cover the entire bar. I did mine without doing the usual 'stick an inch or so into the end of the bar before wrapping' trick (it's too thick to fit plus the bar end anyway) and even then I went right to the end of the roll and still felt like I should have had an extra couple of cm on the handlebar covered.
Identical to the one I've got then, hopefully the smooth end will be shoved in the bar ends and the other smooth edge will be taped over, depending on how much smooth edge there is.
I've got a nice Ritchey WCS C260 130mm stem (2nd hand for £30, not the £75 new price!) to go on and the bars I'm waiting for are the Ritchey WCS Logic II's.
Congrats on getting round that - how did the bike hold up?
Cheers!
Could have been better - took it to the mechanic there before the start, he made a small adjustment to the b-tension and the limit screws, but then realised I couldn't get into my bottom gear so was limited to 34-23 for most of it. I trimmed the gearing whilst on the move to try and get that to shift it up and that worked, but shifted the other gears out, but at least it gave me 34-25 for the 20% climbs!
Think it'll be ok once I do a few more tweaks. I also need to sort out a creak that seems to have developed in my saddle leading to numerous 'is that your bike or your knees?' Comments every time I came alongside someone. I laughed at first but quite honestly after 150km of irritation I was ready to punch the next person who mentioned it :D
Think I need a 120mm for my new bike - I bought a 110mm on the basis that the top tube was 3cm smaller than my old bike which has an 80mm stem but didn't account for the compact reach of the new handlebars.
I also bought a Rumble Roller and am rolling out my problem areas (calves, hamstrings, IT band, lower back, hip flexors) 2-3 times a week which is doing wonders for my flexibility. Gonna have that stem slammed in no time. :p
Here is my new and first road bike, a 2013 Cannondale CAAD8 Sora. I have been out for 2x 18km rides so far and it was good fun, if a little sore on my bum, hamstrings, neck and back due to the position etc.
I bought this from Evans and they offer a free service which I'll take advantage of.
I do have some questions, however:
  1. When I am in the gear which is hardest to peddle in, something seems to rattle. Is this normal?
  2. What grip/position should I be using when cycling on the flats? Should I be down on the drops or should I be higher up around the gear changers? i.e. should the part between my thumb and forefinger be around the top of the gears? I tried this and found it hard to get to the brake lever.
The rattling might be the chain scraping the side of the front derailleur. Try tightening/loosening the cable using the barrel adjustor (there's probably one on your gear cable somewhere) while pedalling backwards until it goes away.
You can have your hands wherever's most comfortable but you'll be more aerodynamic on the drops. On the hoods (the top bit that sticks out) will probably be the most relaxed position for general riding (especially in traffic) though.
The brakes are slightly harder to use while on the hoods due to less leverage but you get used to it. Try rotating your hands outwards slightly (so you press down less on the centre of the thumb/forefinger webbing and more on the base of your thumb) so your fingers wrap round the brake lever easier. You may find this more comfortable for your shoulders too.
1. Turn the bike upside down, put it in 'top gear' and spin the pedals. Is the chain rubbing against the front derailleur? If so then its an easy fix.
2. People tend to spend 95% of their time on the hoods, which is the tops of the shifters. It's usually the most comfortable.
Did you have the chain on the big chainring at the front or the smaller one? If you have the chain on the small ring at the front and the small sprocket at the back then the noise will probably be the chain rubbing on the front shifter. You should try to avoid using the biggest sprockets at the back when you are in the biggest chainring at the front and also the smallest sprockets at the back when you are in the smallest sprocket at the front.
Just personal preference. Most people will ride with their hands on the tops of the shifters ('hoods') or on the flat bit of bar near the middle when casually riding as this gives the most upright position and is more comfortable. When you want to push harder and go as fast as you can, it's better to use the drops because it moves your shoulders down and makes you more aerodynamic. You'll also get more leverage on the brakes from the drops, so thats better for going fast down hills.
Status
