Road Cycling Essentials
Status
Not open for further replies.
Oh FFS! :mad:
I've been riding the Canyon to work as my CX needed a new bolt for the seatpost clamp. I popped in to the LBS today to pick up a cheap seatpost clamp I could salvage the bolt from. I get it home, go to install it and 'pop', the head comes off the crappy bolt. Now I have the threaded bit stuck in my proprietary clamp (with a canti brake stop/hangar thing built in).
I need my CX back on the road because of the rain forecast for tomorrow. :(
I think I bought some High5 gels, meant to taste of raspberry and orange (separate flavours). They tasted disgusting.
I don't always remember / bother to cook flapjack, or buy soreen... are there any gels out there that taste NICE?
I like the SiS ones, they're a bit runnier which makes them easier to digest and they don't have that rank salty aftertaste a lot of gels have.
That said, I stick to solid food when riding. Much more enjoyable than energy drinks or supplements. However, as intensity increases your body's ability to digest solid food decreases so gels/drinks certainly have their place, particularly in racing/TTing.
[Damien];24428566 said:
Oh FFS! :mad:
Never mind. I fixed it. :)
Needlenose pliers ftw
you literally don't have enough muscle to unscrew it?
It's ok, I manned up/ate some spinach. Was on there pretty tight though, since I bought my bike 3 years ago no less.
:D
And haters gonna hate...
Never heard this before. What's the sampling rate on a Garmin?
I've had my Bryton 40 for about 8 months and had no issues with it, and data seems to pretty much match that of my mates who use Garmin.
I haven't looked into it but all his Strava times are multiples of 5, whereas even mine on the lowest spec Garmin seem to be are to one second.
I have a Retul bike fitting at Planet X tomorrow so time to see how badly my bike is set up for me!
I'm getting the Ridley Orion Summer Edition, it's not the colour I wanted being all black with white decals, but after sitting on quite a few bikes, the Ridley just felt right. The bike shop were very good doing my fitting and seemed to know their stuff.
I have had my Ridley since January, looks a similar spec, but was last years Orion 105B, rides really well even on poor roads. Enjoy
Regarding Gels, if you can't stand the flavour, myprotein orange ones are really nice, bit sweet. Also the calorie intake in a gel isn't the important thing its the amount of carbs in it that gives you the boost.
:D I reckon he's just cheating then!
Been using my Bryton with Strava since i got it, never seen anything like that. All my times are to the second.
I think the times being multiples of five is just a coincidence, the problem as I understand it is:
the Bryton apparently samples every five seconds which means on a short segment you could ride 100 metres and have a GPS sample at 10m and 90m and Strava for some reason rounds down to the nearest pieces of GPS data. This means you would get a segment time that only covers 80m. I'm not sure if this is true as I can't find any official confirmation either way. The only certain way would be to record the same ride with a Garmin and Bryton and compare.
Let's face it though, there are so many competing devices uploading to Strava that the data is never going to be 100% comparable. It's for fun at the end of the day.
Lockrings can be really hard to get off. I have a 2foot breaker bar that my cassette tool fits on and even that can still take a lot of my 13stone weight on it before it'll shift.
Thankfully, its still much easier than older screw-on style freewheels but still can be a right pain.
[Damien];24429866 said:
Goodbye for now Canyon. You had a good run. I'll see you at the weekend :(
Tomorrow's commute is going to suck...
wuut why? if its because of rain then man up.. a little water or dirt wont hurt the bike.
I know a few people would say the same as you grudas but I'm with Damien, riding it to work just means more opportunity to damage it as well as leading to more drivetrain maintenance. I also run softer tyres on my weekender that wouldn't last one commute through the glass strewn roads of inner Manchester!
It also makes you look forward to riding the nice bike. :D
but its not like you're replacing your commuter with your nice bike now is it? its a temp soliution while you get the correct parts.. a week of some water on drivetrain wont kill it.. it'll be dirty but jeez its there to enjoy! its like buying an f40 ferrari and storing it.. where you're meant to abuse it like it was made to(ehem our forum member eyedot is a good example with his f40)
The High 5 ISO gels have the runny consistency, I think people complaining about their taste must be talking about the other ones because these barely taste of anything!
how tall are you? That frame looks TINY
He's not THAT small, I'd say.. compact..
Status
