770 in SLI or one 780?
get the 770 SLI its only slightly more expense than a single 780 depending on what model you get
i have 2 770 lightnings in SLI and the same BenQ monitor and most games run 100+ fps maxed out
also the 780 is massively overpriced for what it is and will depreciate in value fast
while the 770s are more reasonably priced and should hold their value better if you want to sell them later on for the next generation cards
Get a 780 surely you'd want the 3gb over 2gb.
But if your willing to buy 770 sli just buy one Titan :D
The 770 I am planning to get is the 4GB version not the 2GB version, and another reason why I chose the 770s over the TITAN was that I could buy one now then upgrade a month or so later, buying a TITAN is a lot of cash in one gulp
I agree with you, thanks :D
