id rock that and pwn your PB's on hill climbs! don't tempt me.
I realise this isn't strictly road cycling, but my queries are noddy enough that I'm sure you guys can help me.
Where I work is offering the C2W scheme, and I'm giving serious thought to using it, since the salary impact is so small over time. The likelihood is that I'll do more recreational cycling than going to work (although I'll need to use it that way from time to time to stay within the conditions of C2W), and even when I cycle to work, I'll avoid roads whereever possible since I'd prefer to stay out of harms way! It will see more use on cycle routes and light trails.
Enough rambling, my questions are around equipment. I've selected the items below from the research I've done, but would appreciate any and all input.
http://www.halfords.com/webapp/wcs/...uctId_810735_langId_-1_categoryId_165499#tab3
http://www.halfords.com/webapp/wcs/..._productId_851967_langId_-1_categoryId_271408
http://www.halfords.com/webapp/wcs/..._productId_889193_langId_-1_categoryId_165741
http://www.halfords.com/webapp/wcs/..._productId_921379_langId_-1_categoryId_165636
http://www.halfords.com/webapp/wcs/..._productId_189730_langId_-1_categoryId_228377
http://www.halfords.com/webapp/wcs/..._productId_217868_langId_-1_categoryId_165661
Please, treat me like a total novice, since I am!
Thanks.
Has anyone got any planet x jerseys, was going to order a few of the cheap ones for the commute and shorter rides, just wondering if they're any good, only £10 each atm.
I've got one. Went for a large and its a bit tight tbh. (I'm 6ft around 13st)
Nice enough though and bargain for £10.
d
[DOD]Asprilla;24444340 said:If you are using cycle paths and light off road then get the Boardman Hybrid Comp instead. It's a much better bike, especially for what you want, and it's cheaper.
[DOD]Asprilla;24444717 said:The mtb is well specced but its still an mtb and because of that I feel it's got the following against it:
- lack of mudguard mounts
- 36/24 gearing (seriously?)
- front suspension that isn't required
It's a good bike for the cash, I just wouldn't recommend it for commuting.
Thanks.
Tremendous input guys, really appreciate that. Any recommendations on other lights? I'd only picked those to "be seen" as you stated, since when it's dark in the evenings (winter) I'd probably chicken out of going out on it anyways!
Tyre repair info sounds 100% logical, I'll adjust my choices accordingly.
I've got a reasonable selection of clothing from doing other sports and running. Probably need to invest in some decent shorts though.
I'll wait and see what other opinions weigh in on the bike discussion - technical comments on the gearing and suspension type are way over my head at this point (I'll go and read up), I was just going off general research for a bike that was primarily light trails, with some (secondary) commuting.
Mudguard mounts don't bother me, as I can shower and change at work.
Thanks for this guys, I hate being a noob but it's nice to receive friendly advice.
So would I be better looking at (one of which suggested above) the likes of these two given my proposed usage mix?
http://www.halfords.com/webapp/wcs/..._productId_810635_langId_-1_categoryId_165534
http://www.halfords.com/webapp/wcs/...uctId_777849_langId_-1_categoryId_165534#tab2
