I've never cracked a phone screen as of yet. I've had an s2 which the bottom half of the touchscreen stoped working.
Same here never cracked a screen yet (touch wood), I guess you just have to be careful and use a case which protects the screen.
Yeah that does look pretty good, shame they went and used the GS 3 camera and LCD screen instead though!
But how does it fare when it comes to drops?
yep I always buy a full covered case and screen protector for every phone I get. tbh I don't care how it looks as long as it protects it. because phones are not cheap.Same here never cracked a screen yet (touch wood), I guess you just have to be careful and use a case which protects the screen.
Interesting phone the active, it looks quite good tbh better then the GS4. The camera on the GS3 wasnt too bad at all plus the screen is still 1080p might be a great phone.
Should have gone with on screen like the XZ.looks of the phone is not so important to me. whats important to me is features, spec/hardware and ease of use as I use my nose to control the phone.Out of curiosity, what goes into your buying decision for a phone? Do you care about industrial design etc, seeing as it's going to spend its life hidden?
The worst thing I've ever done to any phone is chip a bit of the plastic case when removing it to change batteries.
What on earth have you guys been doing?
Loads of people have said the blue ones are meant to be much easier to fix as the glass is meant to be thicker...
I leave that one for you to test and report back here how well it handles drops...But how does it fare when it comes to drops?
I just finish replacing the front glass on my Blue S3....Cracked my white S3 screen a few months back. Decided to try and fix it myself, so I bought a new screen plus adhesive for around £15. Few hours work and it was as good as new!
Few weeks later, I lost that phone and decided to buy a blue S3 replacement off eBay (I didn't have insurance, or the money for a brand new one) with a cracked screen. £15 and a few hours later, sorted.
The blue phones are definitely a lot harder to fix though.
I might be wrong but the replacement glass I fitted don't seem to be anywhere near as good as the Original glass...
(it feels/looks more like plastic and it even maybe some kind of plastic instead of glass)
