ah awesome! thanks. i'll take a ganders now![]()
Cool - let us know if you like it.
Anyone know how we check the camera firmware version?
Thank you again for a very detailed responce
I know how to root and flash ROMs on my Nexus but there is an all in one app that pretty much automated the whole process (Nexus ToolKit).
I'm assuming installing ROMs is the same as its done on the Nexus....reboot into recovery, clear cashe, dalvik cashe, install rom, install gapps...?
When I got my Nexus I made a few glaring errors. I remember a few times I wiped the whole phone and then struggled to send the rom and gapps files to it. Finally managed using nexus toolkit app which sent them over and flashed automatically. Saved my bacon a few times that app! Is there a similar app for the S4 where you can create backups, root, unroot, transfer files, flash ROMs etc etc?
Can anyone comment on the above please.
+ Can i use the "CF-Auto-Root" method by ChainFire to root?
Model: GT-I9505 (4.2.2)
PDA: XXUBMEA
PHONE: XXUBMEA
CSC: OXABMEA (MultiCSC - 8 codes)
Kernel: 3.4.0-768421 (30.05)
Build Date: 29.05.2013
Changelist: 768421
No there's no all in one toolkit, not as yet. Still it's not very complicated all the same. No gapps with Samsung roms for a start. There is a CM10.1 + gapps, but then you won't have all the cool Samsung sensor tricks.
CF-Auto-Root is one method to root yes, another is to flash an entire stock rom that's been deodexed and the bloatware removed. After that a custom recovery is the normal way to go. Depends what you're trying to achieve? Just the root? Custom rom?
PA isnt the google experience. if you want PA then try the pacman rom. if you want google, then yes;cm10.1 is probably the way to go. if you want samsung trickery without the touchwiz stuff then you want wanam with JB domination theme or foxhound.
There's a lot more to a rom than just the theme. PA with it's multi DPI/PiE/Halo is pretty far removed from stock android.Stock PA, CM10 and Android 4.2 all the look the same to me in their bare state.
then try pacman![]()
Is it stable?
I guess i will loose all of the Samsung Sensor stuff and the camera quality?
Q: Will the Samsung apps and features work on this rom like Smart Stay, Smart Scroll, Multi window?
A: No they won't because this is based on AOSP/CM and therefore doesn't have any of the Touchwiz/Samsung which all the Samsung Apps/Features require... If you require these features stay on a stock based rom![]()
Ahh man!!
Sounds like its pointless having this phone if your gonner install a AOSP/CM rom on it :/
I really want the camera quality- main reason i upgraded to it (and the 1080p screen).
Im not too fussed about Smart Stay/Scroll/Multi window. Its the camera i am really bothered about
Best thing is to just do what matt has, wanam, domination theme, install the stock android/cm apks
