Cheers for your help mate!
Do i install CWD recovery the same way too (Using Odin PDA method)?
Thanks Man
MEA installed. Now on the android is upgrading screen.
How do i check if its now rooted?
I want to install wanamlite rom but running into a few problems. I'm trying to root the device using TWRP, I go into download mode, load up odin everything is as it should. I choose the TWRP recovery file, flash, completed without errors. Now when I boot into recovery mode it loads up the default android recovery menu not TWRP, any ideas?
Try redownloading it, it may be a corrupt file
I keep getting signature verification error when trying to install ROM in CWD recovery. I've checked the MD5 checksum and it matches the file on my PC.....any ideas.....
Can you put up a screen shot of the Odin completed thread?
This one? > openrecovery-twrp-2.5.0.2-jfltexx.tar
I was using maps navigation earlier and a pop up box appeared with an upgrade to something like voice hd but I cancelled it as I was in a rush but now I can't figure out what it was. Anyone got any ideas?
Looks good to meJob done?![]()
Try this for me: Turn it off, should give a little buzz when it's done. Hold volume up and the power button, nothing else. When (or if) you see the blue writing in the top right hand corner let go. What happens?Heres the screen. Ran odin as administrator. Same outcome, boots to android recovery
