Good to know. I noticed that when using 320.18 it would load BF3 in a window and I had to click the maximise button to full-screen it (ALT-Enter didn't help).
Just ordered a 770. What drivers should i use! I don't want to break it the minute i get it!
or 320.11 (effectively the same I believe) that is on the Asus site and some install CD's.
320.18.or 320.11 (effectively the same I believe) that is on the Asus site and some install CD's.
I wouldn't worry about it Jono. You have plenty of warranty![]()
So this problem only affects 600 series cards then?
Ive seen it across a few friends rigs, massively overheating, a mix of 5 and 6 series GPUs
Cards with issues were a 570 , 570 SLI, a 680 Reference
Yep, all back to normal on every one, luckily with no artifacting, but since I'd built all the systems the case cooling was very good on all of them so I suspect that may have saved them. I saw it first hand with the 570 sli, it would burn your hand on the exhaust area and the fans were going full tilt
