I think this PSU is dying D:
I've had my Seasonic for 6 years or even more now! Still going really strong with voltages dead on! Only had to replace the fan as the old one started to tick.
A few years back I used to think on of my GTX460s was faulty... until the instability got to me and I splashed on a new PSU.
Guys, I'm looking for a replacement for this PSU - can anyone recommend something very reliable? Perhaps modular :) budget around 60-80 but preferably lower! has to be able to power the rig in blue in my signature safely
Been there, done it! paid the price etc :rolleyes:
Had an Antec earthwatts psu burn out and take the board with it. Another two non-standard Antec units in mini-atx cases popped, one flamed up and made the place stink for days.
I also had an FSP Bluestorm 500watter. It had a fancy led power switch and over the course of a week start to fizzle and pop. Lots of funky electric smell (ozone? not sure what you call it) and then finally it melted. I initially tossed the psu into a box, left it until I put in a new switch so has been working fine ever since. I would not have bothered if it had been a really cheap psu.
Sorry chap but that's not a valid excuse. They are crap. The psu is the single most important component in a pc and is not the place to skimp. A extra fiver would have got you a far superior 650w XFX (built by Seasonic). Buy cheap, buy twice!!
+1
If it takes out components then it may cost you even more than that
Sounds like a relay is engaging, then disengaging. Maybe a relay is how PowerCool have designed in protection and instead of just cutting power and refusing to start again this one just comes back on again, and then trips again. I particularly like the way the fan spins up and then slows down repeatedly through the video.
The fan speeding and slowing was just how it looks on video :P strange trick of the light
Another strange query with this, I've built a frakenstein PC out of the parts I have left. The only PSU i have hanging around is a basically crappy 230watt grey thing - I'm using the cheapy asrock board from my sig, the phenom ii x6, 4GB ddr3 2x2gb -card - geforce 630GT and 3 sata hdd's.
I've reinstalled a fresh OS temporarily, but the PC will randomly shutdown by itself, I reinstalled folding at home and was running it, then all of a sudden the PC totally died, no blue screen or freeze up, just went off totally - it turned back on and booted absolutely fine, then the same thing happened again 3 times in a row, is this because folding is drawing too much load from the PSU to supply the CPU and GPU?
Lol, please for the love of god throw that PSU out and buy something better before you do some damage to your parts :rolleyes:
One of these will do the trick if you are after something cheap and reliable. I have one in my backup rig (in sig).
YOUR BASKET
1 x OCZ CoreXtreme 500w '80 Plus' Power Supply £34.99
YOUR BASKET
I had an OCZ Stealthstream 650watt for about 6 years :D
Hmm, do you not think I should hold on till I buy my new rig? Reckon that the current PSU will kill it? :P
The current PSU will probably do some damage to something. :rolleyes:
It cant provide enough power... If it's a cheap grey-box, it might not even output 230W. Lets say for arguments sake that it is actually outputting 200W, the system you are trying to power needs a tad more than that. A quality 350W PSU would do the trick. And that 500W CoreXstream will give you some headroom for if you wanted to add a slightly more power hungry GPU for folding. (like a 460, 470, 560TI etc)
Would the 500watt corestream psu run flat out folding on a 6970? :O
The CoreXstream can only deliver 444w on the 12v rails, suffers from high ripple and in the one review i could find, got a less than stellar rating. I would never recommend one even for a budget system.
Not sounding great is it, saying that need to jump on and grab a XFX supply for the aging celeron family pc. Just teared open the case and its a Sumvision Power X 500W, not sure I trust that thing as far as I could throw it. Then again it is still going after 4+ years.
