http://www.overclockers.co.uk/showproduct.php?prodid=CA-040-SS&groupid=701&catid=123
There's been a buzz about the XFX ones recently...
Sorry chap but that's not a valid excuse. They are crap. The psu is the single most important component in a pc and is not the place to skimp. A extra fiver would have got you a far superior 650w XFX (built by Seasonic). Buy cheap, buy twice!!
Sounds like a relay is engaging, then disengaging. Maybe a relay is how PowerCool have designed in protection and instead of just cutting power and refusing to start again this one just comes back on again, and then trips again. I particularly like the way the fan spins up and then slows down repeatedly through the video.
Another strange query with this, I've built a frakenstein PC out of the parts I have left. The only PSU i have hanging around is a basically crappy 230watt grey thing - I'm using the cheapy asrock board from my sig, the phenom ii x6, 4GB ddr3 2x2gb -card - geforce 630GT and 3 sata hdd's.
I've reinstalled a fresh OS temporarily, but the PC will randomly shutdown by itself, I reinstalled folding at home and was running it, then all of a sudden the PC totally died, no blue screen or freeze up, just went off totally - it turned back on and booted absolutely fine, then the same thing happened again 3 times in a row, is this because folding is drawing too much load from the PSU to supply the CPU and GPU?
Lol, please for the love of god throw that PSU out and buy something better before you do some damage to your parts
One of these will do the trick if you are after something cheap and reliable. I have one in my backup rig (in sig).
YOUR BASKET
1 x OCZ CoreXtreme 500w '80 Plus' Power Supply £34.99
I had an OCZ Stealthstream 650watt for about 6 years
Hmm, do you not think I should hold on till I buy my new rig? Reckon that the current PSU will kill it?![]()
The current PSU will probably do some damage to something.
It cant provide enough power... If it's a cheap grey-box, it might not even output 230W. Lets say for arguments sake that it is actually outputting 200W, the system you are trying to power needs a tad more than that. A quality 350W PSU would do the trick. And that 500W CoreXstream will give you some headroom for if you wanted to add a slightly more power hungry GPU for folding. (like a 460, 470, 560TI etc)
