Watercooling an i7 3770k With No IHS - Direct Die cooling
3 Jun 2012
hey all
I plan to De Lid my 3770k this week and run it lidless to get the most from the chip.
The chosen method of De Lidding the 3770k i will use
http://www.youtube.com/watch?v=Bg9ybeB4DDw
It Looks MENTAL so i LOVE IT
a better vid
http://www.youtube.com/watch?v=fbZTF5PYdgE
My current Temps are High, an example is the pic below with my current overclock with 1min of prime 95:
I managed to find a Full Nickel EK Supremacy, all mounting kit included.
Same as: http://www.overclockers.co.uk/showproduct.php?prodid=WC-230-EK&groupid=962&catid=1519&subcat=2286
I would have liked the clean version but i cant be picky!
The most important part of the setup is the new EK Mounting kit that is made for direct die cooling, Without it there is a massive risk of crushing the core so it a worthwhile investment!
Also its so cheap that why not get it !
http://www.overclockers.co.uk/showproduct.php?prodid=WC-350-EK&groupid=962&catid=1519&subcat=2287
Doing all this would be pointless if i carried on using MX-4, so i decided to take the plunge and get some Liquid Ultra cooling paste, This is supposed to be the best of the best and at a few quid more that MX-4 i didn't mind.
When all the bits come i will start the process, I have decided to change my D5 Pump/Top res into a Normal top with an EK Tube res at the same time, and finding space in a Parvum s1.0 will be tough considering i have a 7990 on the way as well.
So bare with me :)
I have the same CPU and I need the same voltage as you to 4.5ghz...
I get around the same temperatures as you on prime but I'm using a Corsair A70 air cooler.
Interesting...
I wonder why my temps are so bad.
I have a new block and mounting hardware on its way anyway so will see what happens.
@ Diagro, I ordered the EK direct mounting kit the other day as I'm gonna delid my 3770K and mount the Raystorm waterblock straight to the die too. Hopefully it will be delivered soon.
What cooling do you have? What were your temps before you delidded?
I'm gonna order http://www.overclockers.co.uk/showproduct.php?prodid=WC-204-EK&groupid=962&catid=1519 when I finish work along with some new coolant.
YOUR BASKET
1 x OcUK Tech Lab - XSPC D5 Vario Pump & EK-D5 X-TOP CSQ Plexi Combo £81.98
1 x EK Water Blocks EK-Supremacy - Nickel £56.99
1 x EK-RES X3 250 Reservoir £51.98
1 x Mayhems X1 UV Clear Blue Premixed Watercooling Fluid 1L £7.99
1 x Primochill Primoflex Advanced Tubing 16/11 - Clear £5.99
1 x EK-Supremacy PreciseMount Add-on Naked Ivy £3.95
8 x XSPC G1/4" to 7/16" ID, 5/8" OD Compression Fitting (Black Chrome) £2.99 (£23.92)
Total : £244.19 (includes shipping : £9.50).
and an Alphacool Monsta 240mm with 2 pull AP-15s on, I intend to get 2 more.
My temps were v1.33-35 4.7GHz hit 95 P95 on a K2 full pelt. Delidded and that hit 70-75. Now I'm at 4.8 with the water. :)
YOUR BASKET
Got any pics of the rear or the mobo and the mounting hardware? Will be interested to see
YOUR BASKET
Cool. What TIM did you use between the die and the waterblock?
My watercooling setup is: Res - pump - 280mm rad with push/pull fans - GPU's - 420mm rad with push/pull fans - CPU - Res.
The Ivy mount kit arrived, Though i cant understand why there is only 3 washers? o.O
the Pack shows its supposed to have 3, yet the pic shows them being used with 4!?
I think the washers should be used on the 3 screws that hold the original CPU lock system.
Actually on their picture they use more than 4... one under each thumb screw plus on the original lock system screws.
