RAID 0 Array Showing Smaller Size Than Expected?
jb7
jb7
28 Jul 2009
I have a 500gb and a 250gb Samsung 840 SSD's.
I have created a raid 0 array in my motherboard's bios, however the total size of the array is 465 gb (I've definitely selected raid 0, and not raid 1)
Any ideas? It doesn't seem to be using the second drive....
Thanks!
Forgive me if I'm wrong, but if you're using two different sized drives in RAID 0 then you're only ever going to get twice the capacity of the smallest drive, which, after formatting, is roughly what you have.
The RAID is writing half the data to your smaller drive and half to your bigger drive, so only using about half of its capacity. You can't set it up to write 2/3 to one and 1/3 to the other.
Ah I see! Thought it worked with any size drive
Oh well, I'll keep the OS on the 500 and games on the 250
For the optimum experience it's typically the OS on the ssd. The much faster random read and low latency make an ssd ideal for the OS. The HDD can be used for less frequently accessed games/media. And the 250GB is large enough for the odd game that may benefit from being installed on the ssd instead.
I don't generally reccomend RAID with SSDs unless you need raw transfer rates as the overheads can reduce one of the biggest advantages of having an SSD - really low access times.
He has two SSDs, no HDD involved.
