What's the best recovery and where from? Do you use Goomanager or whatever?
Anybody used the newer prerooted ROMs from XDA?
they all allow you to install zips and wipe cache etc, which are the only things the vast majority of us use them for. For that reason id say close your eyes and pick one
Although, i use philz just because it's a bit flashier lol
THe smearing issue will be present until somebody finds a way of keeping the pixels let. You can do with with screen adjuster but it means having an extra app running. Although the improvement is pretty large, it just isnt worth it. Dont know what it does for battery life either, havent tested that.
duc999 said:
Installed 0.6 and didn't like it , uninstalled Going to look at different ROMS
What didnt you like? maybe we could suggest something if you tell us why you didnt like it
I'm using CM10.1 on a nightly from a few days ago and I finally got round to using the audio player on the train yesterday and there was awful crackling, is that a kernel thing?
Yep
Do you get it on the latest wanam? I might go back tbh.
not if you are using AdamKernel 1.
4, i believe. <1.4 was still based on older kernels (pre-MEA) but im using 1.4 (mf4-based) with foxhound 0.6 and no crackling here, so i would assume wanam would be fine also
just so people know, foxhound 0.6 comes with KT kernal as stock which doesnt support exFat, but other kernels can be flashed easily enough.
