Cool Trick From Dynamo
Not a very well concealed trick. His arm stands out a mile away, very obvious judging from the video. Good tricks can be awesome, this however was not a good trick.
Just seen this :confused: how does he do it?
Bet you wish you had never asked now...
Very simple indeed.
He is supported by metal work across his shoulders and maybe waist connected to the bus through supports along his right arm.
This, it was obvious within like 5 seconds. Watched ot the end to see if he ever lets go of the bus, nope.
Not sure whats worst, that it somehow passes for illusion these days or the cringe worthy commentary in the video.
EDIT: To be fair its a pretty cool in a "stunt" sort of way but not even in the same league as a decent magic/illusion trick.
It has a coolness as a kind of obvious trick and I would watch him go past, but the sheer look of shock and bewilderment of some of the passersbys, WTF? Some of the spectators look and act as though Jesus walked from the Thames.
pretty rubbish 'trick' - if anyone with half a brain can figure it out in less than 3 seconds it hardly qualifies as a trick.
+1, I really fail to see what the fuss with him is.
He does some quite cool stuff but then ruins it with this sort of thing. Same as when he "walked on water". When there is only one simple explanation for how an illusion is done, its never going to be very good.
Everyone knows that magicians and illusionists are tricking us, the good ones just do it in a way that is hard to figure out rather than rehashing tricks that are old and simple.
a lot of the videos he does are paid actors apparently.. hes just like conspiricy theorie videos.. people just believe they must be real and not setup
Same technique used by the many people levitating around Covent Garden. I can't believe that anyone is unable to work this out in less than three seconds.
The Covent Garden ones are cooler because it's obvious some thought had gone into the props and method of hiding the supporting metalwork.
An 'arm' is just lazy.
