Who runs a rear mech with a clutch?
Who here runs a Shimano one?
If you do, how loose is your clutch lever? You know, the lever that turns it on or off? Mine is really loose and easily can be moved to the off position. I dropped the chain the other day a couple of times, and both times I looked down and noticed that the clutch lever was set to the off position (with it 100% previously set to on). Is this happening BECAUSE I dropped the chain, and as a safety mechanism or stresses on the mech it does something to turn/knock if off? Or is is shaking itself to the off position and CAUSING my dropped chains?
Any advice? Can I open it up and make the lever stiffer to stay turned on?
