You're putting eichar brakes on a 335?
Tbh expensive pagid ones were crap, let him see if cheaper ones fix his problem for the grand sum of £26.
There's some sort of funky micrometer gauge you can get to check for disc warp (I've seen Edd use it on Wheeler Dealers!). Disc warp is rarely visible to the eye, but it only takes <0.5mm or so for it to be noticeable through the pedal.
Having said that, the fact that you've stripped and replaced a couple of times, each time temporarily solving the issue would seem to point to it being the caliper and not the discs themselves.
Thanks for the update. My bet is that they'll get worse in the next few weeks. Ill update with the result of my garage appointment on Monday.
You had any more luck Brad? I've ordered some Bosch disc's and pads. Sod Pagid. Apparently ECP have bought exclusive rights to use the "Pagid" name which they are sticking on cheaper stuff. I think i may have had shoddy quality discs and pads.
Cant believe people are moaning that cheap brake parts don't perform brilliantly, why not just spend a little bit more for some better parts?
Mechanic checked all bushes, wheel bearings and if the wheels were free to turn and all was ok. Went out for a drive with him and he noted that the hotter the discs got, the more the wheel vibrated so it's probably crap discs that have been manufactured poorly as it appeared quickly after I fitted them. Hope it's true. Also should be able to hopefully get my money back from ECP for my old Pagid stuff which will offset the cost (and put me £30 up!) if they can sort out a refund.
Check out "www.mister-auto.co.uk" they do a far better range of braking parts (ATE/Delphi/Textar/Bosch) than ECP and for much much less.
Hopefully should have new front discs and pads fitted by tomorrow so i'll update then.
When i replace mine, ill be going for ATE, and ill update the thread too
