Thanks both paintguy and Audigex: Your replies are almost consistent / similar to what I was planning.
1. Yes WHS is almost a given choice. £35 is cheapest in the UK and I don't reckon I want to wait longer to get it cheaper
2. Paintguy suggested '
starting' with stock 250GB with
both OS+data shares on the same (and only drive) - and 'replicating' for BOTH (?) OS and data shares for offline backup on the 500GB external WD I have. That seems a
good to start as I dont have to do anymore investment than the £35 WHS,
and I am good to go with
offline backup strategy of both OS and data on the external 500GB.
3. But getting greedier- as
Audi also suggested wisely- invest in '
atleast' one WD RED (
2TB perhaps or strech a little 3TB)
AND an external 2TB or 3TB USB external backup (
depending on whether I go with 2/3TB WD Red).
That will provide
data share on the WD Red + OS on the 250 GB and
offline backup on the external USB brick.
(What about OS backup stragey then? Is that a must? What if OS crashes/server falls?)
I am considering below retailer for a 2TB external for £60 or 3TB for £78.
http://www.******.com/412333-toshiba-2tb-stor-e-canvio-external-hard-drive-hdwc120ek3j1
That is, £18 extra for a TB (external).
- And for the box, WD Red's 2TB (£83) or 3TB (£113) which is £30 more for a TB, from amazon.
Which means : £190 (for a 3TB box+bak) solution or £133 for 2TB solution
4.
RAM- I will see how 2GB stock goes, unless I get a £10 2GB stick soon.
Thanks for suggestions - I *
know* decision is mine - whether to stick to 250GB + 500 GB (bak) solution or full blown 3TB + 3TB (bak), which is my dream if wifey gives in.
Still, more suggestions welcome...
But for the above I have to take permissions from wifey which is a BIG challenge.
