Different colours Photomatix - Adobe!
Caporegime
8 Sep 2006
On Ocuk
Not sure why it’s doing it but Adobe Photoshop is making not only the colours look wrong but the sharpness as well. Now I save the Photomatix shot which is nice and sharp with good colours as a tif. Open the tif in adobe and it looks completely different. If I use Topaz Labs filter in Adobe, which opens a seperate window, it’s the same colour as the Photomatix one.
I’ve set the Cache level to 1 and still no change.
Basically every single application other than Adobe is the same! :mad:
Can anyone recommend another application good for photography editing?
Rather than changing editing software, why don't you solve the problem? You've probably got your colour profile not set correctly.
kd
I kinda thought this thread was trying to do just that
It was set to " Monitor Color " I think I'll reset it back to SRGB, see if that makes a difference. Haven't used Photoshop in a year and had many driver changes since then
Cheers
your comment about looking for other editing software made it sound like you didnt want to solve the problem rather find a different software all together
either way, the daddy of photo editing is : Lightroom
I found out what's causing it!
Even though I had set to SRGB it was still opening in the wrong colours and sharpness, turns out adobe bridge was opening the layers with Adobe Photoshop 64x, which I don't use and has default settings. Preserve embedded colour settings also needs to be ticked in bridge.
EDIT : Nope still doing it, Photomatix is completely different to everything else now :(
Photomatix - Yellow Tint / Adobe/Windows Gallery/Bridge - Purple Tint
