Oops hhahah sorry, my mistake, I am just in love with those red fans and the finish on the blades.![]()
They won't be going to waste I assure you
They are now put aside for a future build
that loooks awesome
If my cards don't sell I'll be doing this
If you don't mind me asking, how much is the cooling alone costing you? (excluding fans)
Thank you, I was hoping it would have that effect
Ok the actual cost which includes the bay pump/res, rad, shroud, CPU block, the GPU block and backplate plus the compression fittings weighs in at around 350 quid.
That excludes the cost of the fans, angled fittings and extensions, tubing and coolant.
It's not cheap and I've gone for premium kit which also knocks up the price tab some, but if you look apon it this way; you'll likely utilize some if not all of the kit in future builds.
I hope that answers the question mate?
 I already have the GPU blocks, but nothing else as yet. Have the same case though so would be doing a very similar build
Thanks dudeI already have the GPU blocks, but nothing else as yet. Have the same case though so would be doing a very similar build
No worries man, good to hear you know about it. Came to check out the build and realized the problem. Maybe throw up the images on dropbox, never had any problems with bandwidth restrictions from them.
Just a quick post to say thread maintenance has begun and all missing pics should be back up by tomorrow afternoon![]()
Looks good mate! Is that just sitting over the top of the PSU, or have you actually re-housed the guts of the PSU in it?
Cheers,
G
