Permabanned
- 4 Sep 2011
- Durham
Have you got the pump and all the little cables connected properly? A cable of the top of it should have a psu connection and the 2 fans running into it. Bios temps are not important as has already been stated and re-seating will not gain you anything at all. Is the pump lit up? If not is the cable running from the left of the pump to the usb header at the bottom of the mobo? My bios says 50 degrees but coretemp says 32 idle.
