- 5 Jul 2007
- London
If you're using 52/25 and cruising at, say 18mph, then your cadence must be about 110, which sounds unlikely.
Although, thinking about it, that might be why it's "slightly too much" to sustain. If you moved up a couple of sprockets you could maintain the same speed at a lower cadence, which you might find easier.
If you need the range on the hills, change the cassette and move up to a 28 at the back. I think that will help you more than moving to a compact.
It's not good to be cross chaining though. Much better to have a smaller big ring at the front and need less teeth at the back IMO. Also the capacity of your derailliuer will limit you, most short cages can't handle much more than 25 teeth.
I ride with a 11-25 most of the time with a compact up front, rarely spin out and seem to be able to hold my own on the hills.
. And just found out the new Michelin Pro's don't come in yellow. Double
quite nice tbh.. there's a sale going too so don't miss out, nice starters tool kit for 19.99. - can be had for pretty much the same price on amazon tho.
