For £1788 can you better this?
4 Jul 2011
Please help because I can still amend this build, thanks. I require the monitor as a good monitor is vital.
Spend £40 less on the case and spend £40 elsewhere. The HAF-X is overpriced in my honest opinion. For £70 you could easily get a case which is constructed better.
You could put the £40 towards an i7 perhaps. Or a larger SSD, etc.
Well said,
Get a cheaper case, you can great a lot of great cases around £70-£80..
Unless your doing a lot of video editing or virtualization you don't need 16gb of ram. 8gb is perfect for gaming..
You can save £10 by dropping the psu to the 750w version. Will still be enough..
Id personally get a gtx 770 though the 780 is good. :)
tbh i wouldn't spend that amount of money and only have a i5 either
alter vga to a cheaper and better option
alter m/b also and yes agree with others on case as well,
cases only hold bits, so a cheaper option wont do any harm as most do very good cooling now days
We can always rely on you Ether!!! Nice Job!
I will point out that the 600T is a big case and you get a small side window. I would recommend getting a case with a bigger side window or get the all perspex side panel which comes at a cost, but looks amazing.
That's Purdy, but you missed a keyboard..
and why did you go for a more expensive case? :(
I'd personally get a windowed 300R or wait for the Bitfenix Ronin, both £70. :)
And that PSU? Nice but OTT.. I'd get the XFX over that (750W version)
Just for you Doomspeed ;)
YOUR BASKET
1 x Gigabyte GeForce GTX 770 WindForce 3x OC 2048MB GDDR5 PCI-Express Graphics Card (GV-N770OC-2GD) £329.99
1 x Acer HN274Hbmiiid 27" TRUE 120Hz 3D Widescreen LED Monitor with NVIDIA 3D Vision Glasses £280.00
1 x Intel Core i7-4770K 3.50GHz (Haswell) Socket LGA1150 Processor - Retail £275.99
1 x Toshiba SSD HG5D Series THNSNH 7mm 256GB Solid State Hard Drive - (THNSNH256GCST) £163.99
1 x Gigabyte Z87X-D3H Intel Z87 (Socket 1150) DDR3 ATX Motherboard £131.99
1 x XFX Pro Series 750W XXX Edition Modular '80 Plus Bronze' Power Supply £85.99
1 x CM Storm Quickfire Rapid Mechanical Gaming Keyboard - Black Switch £69.98
1 x Corsair Carbide 300R Mid Tower Windowed Case - Black £69.95
1 x Seagate Barracuda 2TB 7200RPM SATA 6Gb/s 64MB Cache - OEM (ST2000DM001) HDD £69.95
1 x Corsair Vengeance Pro Blue 8GB (2x4GB) DDR3 PC3-12800C9 1600MHz Dual Channel Memory Kit (CMY8GX3M2A1600C9B) £67.99
1 x Corsair Vengeance Pro Silver 8GB (2x4GB) DDR3 PC3-12800C9 1600MHz Dual Channel Memory Kit (CMY8GX3M2A1600C9) £67.99
1 x CM Storm Recon 4000 DPI Gaming Mouse £39.98
1 x Corsair Hydro H100 Extreme Performance Liquid CPU Cooler *Manufacturer Refurbished Unit - 90 Day Warranty £39.95
1 x Corsair Fan, SP120 PWM Low Noise High Pressure Fan 4 pin, Dual Pack (CO-9050012-WW) £25.99
1 x Corsair AF120 Performance Series Low Noise High Airflow - Dual Pack £25.99
1 x Corsair AF120 Performance Series Low Noise High Airflow - Single Pack £13.99
Total : £1,790.26 (includes shipping : £25.45).
YOUR BASKET
YES YES YES...
Sorry if it sounds like im sexually excited, its just because I am..
Cannot fault that. :)
Very nice. Oh, and the window on the 600T is not too small. It's bigger than it looks because the case is too :p
thanks a lot guys! but is that screen you choose better than the initial one i had?
It's a 27" 120Hz rather than a 24" 144Hz. Personally I would rather have the extra screen size as I recon' you would be hard pressed to detect a difference between 120 and 144Hz. And in most modern games if you max them out, you wont be getting a solid 120/144 fps anyway. (even with a 780)
But then again it is a hefty amount more expensive.
Agreed, even a GTX Titan will have problem's playing most of the latest games at 144 FPS completed maxed out (unless they were in some crazy badass SLI config and the game scaled well).
Agreed. :)
a 120Hz panel is certainly something I will get when funds allow. Perhaps to go alongside a shiny new GPU :)
I do notice that things aren't as smooth as they could be when gaming, when turning quickly etc.
Ok fair enough am sold then for the 27 inch. Uhm the psu tho will that be enough if in the future I wanted to sli the 770? Nd ohh I need to add a cd reader to that build lol
